Im trying to move my itunes playlist from computer A to computer B. It does ask for a CD but I don't want move so slowly. Can I use a HD instead? When I tried to move info to HD it just creates HTML file.
geposted Tue 22 Apr 08 @ 11:59 pm
I 'm quite familiar with moving an itunes library e.t.c from pc to pc. Just to get something clear. You just want to move the playlists? If it's everything, just copy the itunes folder in your "My Music" folder to the next pc, same place. It'll move over everything. If the music is on an external HD, just hook it up to the next pc after moving the folder before firing up itunes. If it's an an internal HD that's fine too. Just make sure the path to the music stays the same.
geposted Wed 23 Apr 08 @ 7:31 am
