Please please please can anyone tell me why my tracks keep jumping while im trying to mix..I would lay a track down and when I want to put another 1 in its start to jump...any suggestions would be most appreciated!!!
geposted Wed 23 Apr 08 @ 1:21 pm
What?
geposted Wed 23 Apr 08 @ 1:33 pm
If it's a slight jump maybe your computer needs more memory. My VDJ used to do that as well, it used to skip for a sec or 2. I just installed a 1GB of ram then the problem was gone.
geposted Mon 28 Apr 08 @ 8:01 am
The problem may be related to the pc you are using. As the previoud post states it may be related to the ram. it may be worth defragmenting your pc to free up some memory. failing that, try doing all the usual anti virus scans to eliminate that as a possible problem.
geposted Mon 28 Apr 08 @ 3:19 pm
Post your system specs here as well as any programs that may be running in the background. Is this a Lappy?? If so try disabling the wireless internet.
geposted Mon 28 Apr 08 @ 5:55 pm
