Hi, I just bought a 2x CDJ 800 and a DJM 800 and a maya 44 usb hub is in the mail. I was just wondering if anyone had any advice for setting these up and mapping them for someone who doesn't have a lot of experience mapping these.
thanks,
Luke
thanks,
Luke
geposted Wed 23 Apr 08 @ 5:46 pm
Pretty easy to do. As far as the midi...I dunno. That is up to you.
What I would do is run the decks to the maya. Run the maya to the mixer for each channel. Activate the time code in config and select your setup.
Finding what you want to trigger with midi is all you man. Timecode on and off would be a good couple to use up.
Way too tired to think right now. Good luck with it and I look forward to hearing how it works out for you.
geposted Wed 23 Apr 08 @ 11:27 pm
This post should of been in the hardware section. If you do a search in there you will find information DJM800 and midi mapping.
geposted Thu 24 Apr 08 @ 11:41 am
