I'm sure this has been covered, but I couldn't find anything using the search function...
I am replacing the external hard drive I store all my music on, to a larger model. How can I ensure VDJ will be able to use the Virtual Folders, Filter Folders, etc. I've created with the new drive?
(Dell laptop, running XP; using an external Lacie HD)
geposted Wed 23 Apr 08 @ 7:59 pm
Hook up both drives and COPY ALL the data from the *OLD* to the *NEW* keeping everything the same. And make sure you copy the VirtualDJ Database v5.xml file from the root of the OLD drive to the root of the NEW drive.
geposted Wed 23 Apr 08 @ 10:05 pm
I really like the program called Synchronize It. Its only a few dollars and you can use it to copy all of your data over. More importantly it can be used to update your drive with new music. I keep a master drive at the office which all of my new music goes on. When I want to move the new stuff to my external drive this program will transfer the new stuff only. Works great.
geposted Thu 24 Apr 08 @ 11:30 am
