my set up consist of virtual dj vinyls..2 decks mixer and hercules mk 2 as soundcard.My problem is that when i play the two records at the same time,my bpm jump around and are not consistent one would 120 the other 120.5,really starting to annoyed me,need help!
your response is much appreciated!
thanks!
thanks!
geposted Fri 25 Apr 08 @ 2:07 am
Called flutter on normal decks. Use your ears & you will have no problem. If you don't no how to press aync & you can pretend that they are lined up even though they aren't:)
geposted Fri 25 Apr 08 @ 7:08 pm
I had this, In the Timecode config, try changing the Pitch Sensitivity to 2000.
That's what I did. and it stopped the fluctuation.
geposted Sat 26 Apr 08 @ 3:27 am
ah man!!!thanks it has taken u huge weight of my shoulders to think that i was playing like this at my gigs..but i would still manage to pull of my mixes,and i was also close to buying serato,now lets just say that if it happends again would i just have to increase the sensitivity number again?
thankss Man i Appreciate!!!
geposted Sun 27 Apr 08 @ 3:07 am
Yes, but you shouldn't have too now.
And No worries mate, I'm glad I could help.
geposted Sun 27 Apr 08 @ 6:23 am
