Can anybody clarify what does the filter smooth feature do in the performance settings, when is checked and unchecked.
Thanks in Advance
Djpr1
Thanks in Advance
Djpr1
geposted Fri 25 Apr 08 @ 8:48 am
Anybody??
geposted Fri 25 Apr 08 @ 10:40 am
Yo no se....
geposted Fri 25 Apr 08 @ 11:25 pm
Hi, the filter smooth option in the 48khz <->44khz option box will increase the sound quality when playing files that were recorded at a sample rat of 48Khz (DVD audio, for example). It will take more cpu power though. BTW. CDs are recorded at 44kHz sample rate, so the 48kHz<=>44KHz options will not affect standard CD rips (unless you've specifically told your ripping program to do it at 48kHz- but there's not point doing that).
So it'd be best to have it "ticked", but if you have any problems, then just untick it.
Hope that helps.
[Edit] Just noticed that the "scratch" box has a filter smooth option as well. It's pretty much the same thing. Higher sound quality but more computer power is needed for it to work.
Hope that helps.
geposted Sat 26 Apr 08 @ 6:52 am
Thank you andytaylor
geposted Mon 28 Apr 08 @ 7:21 am
