Denon 4500
Virtual dj pro
Denon x500
U46DJ sound card
How do i hook this up and which headphones do i use the mixers or the soundcards..................plus a cd playe is going to be hooked on to the mixer.
Virtual dj pro
Denon x500
U46DJ sound card
geposted Fri 25 Apr 08 @ 6:20 pm
The hip bone is connected to the thigh bone, the thigh bone to the knee bone....OK, load VDJ onto a computer. I believe the 4500 has a sound card in it. If it does, connect it to a usb port on your computer. Connect the RCA outputs from the 4500, to the RCA inputs, on the x500 mixer. You can now configure the sound card and controller in VDJ. You will not need the U46DJ. On the other hand, if the 4500 does not have a sound card built in, you connect the U46DJ to the computer. The RCA outputs to the inputs on the mixer. Then configure in VDJ. You will have more questions, and we will be here to help you. You may also find help, by doing a search of the forum, using key words.
geposted Sat 26 Apr 08 @ 2:00 am
