does any one have a Denon DN-HC4500 & bu4500...................does it all workout fine any thing i need to know before i buy the bu4500 cd player?
geposted Mon 28 Apr 08 @ 5:00 pm
There's some kind of issue with the refresh or something like that. I would go to Denon Dj Forums and do a search, I think that's where I read about it.
geposted Mon 28 Apr 08 @ 5:18 pm
I use both and Im'm very happy with them. The native mapping within VDJ is working fine, just as the sound card. Controlling the cd players is also good. What kkorpos mentions is correct: When you switch from cd player mode to control VDJ, the display and button light are not updated. The VDJ dev team is already aware of this and this will probably be solved in next versions of VDJ.
I'm also beta testing a custom made mapper with very, very much features. This mapper has also a workaround of the issue mentioned above.
Ewout
Ewout
geposted Tue 29 Apr 08 @ 6:28 am
