Automix doesn't work correctly when mixing videos and non videos with sonique plug in. Once a sonique Plug in is ending and a video loads it plays for a few seconds and then skips to the next non video in the playlist. What is the problem and how do I fix it. Numark Cue Ver 5.0.7
geposted Tue 29 Apr 08 @ 2:19 pm
Are you talking about automix function? if not, can you give example of your process your trying to do. Based on the initial posting I don't understand what your trying to do.
geposted Tue 29 Apr 08 @ 3:36 pm
Good Evening , to avoid placing a effects layer over your actual video , you need to disable the plug in and use it via Config > Video set the sonique plugin as the default for audio only files.
This way it will allow you to automix into a video if this is not working for you could you please let us know which version you are using and which automix mode you are using.
geposted Tue 29 Apr 08 @ 3:49 pm
I will say that in automix it happens to me aswell, I just brush it iff, but it does happen
geposted Wed 30 Apr 08 @ 1:08 am
my bad, I didn't read the question correctly...oops
geposted Wed 30 Apr 08 @ 1:28 am
