Has anyone tried a new HC4500 Mapper by PhantomDJ that allegedly works with PCDJ & VDJ? I saw this posting on another board:
http://www.djchat.com/boards/showthread.php?threadid=83685
DenonDJ do you know anything about this?
Thx!
Thx!
geposted Tue 29 Apr 08 @ 3:32 pm
look in the hardware section
http://www.virtualdj.com/forums/89154/Hardware_Technical_Support/New_PhantomDJ_HC-4500_Mapper.html
geposted Tue 29 Apr 08 @ 6:50 pm
Thx!
geposted Wed 30 Apr 08 @ 1:25 am
Hi All, trying the mapper tonight, Live!! i must be mad!!, anyway, one question, how do you disable it??
Any Ideas?
Any Ideas?
geposted Wed 30 Apr 08 @ 3:50 pm
Effects, external devices, select the controller, click on the mapper enabled popup. Then what are you gonna do?
geposted Wed 30 Apr 08 @ 4:25 pm
Yeah that would work, but there is no enable popup!! lol, seems the only way to disable it is to remove it from the plugin/control devices DIR.?
only reason for doing this is that if something goes wrong we can go straight back to vdj native support.
geposted Thu 01 May 08 @ 8:36 am
