I was testing the new Trial version of VDJ5. I have a Core 2 Duo 1.8Ghz and 1GB ram.
I have this brand new GeForce 7200GS Pci-E 256MB it seems that when the image goes to the TV via TV-Out sometimes the videos freeze for 30secs.
How I should i do to minimize that prob ?
geposted Fri 02 May 08 @ 4:09 pm
you may check to see if you have the latest codecs for your video format. I have had issue with my home media system using the TV out on some formats, a codec update usually fixes me up.
geposted Fri 02 May 08 @ 4:19 pm
Codec update ?
I have DivX 6, VLC i think those are the main softwares to run some video formats. Sometimes it plays nicely..but suddenly freezes.
geposted Fri 02 May 08 @ 4:29 pm
You may look for the latest XPCodec pack. Also search this site for "codecs" others have mentioned the codec packs they use but I can't remember them off the top of my head.
geposted Fri 02 May 08 @ 4:39 pm
No codec will help you, GeForce 7200GS is not up to the task to do video mixing. You can try some other card like 7300GT with 256mb DDR3 memory or recommended 8600GT 256Mb.
geposted Fri 02 May 08 @ 5:34 pm
Have that same video card in a pc. You really should think about uping the RAM also especially if your running Vista. I agree with ALF that this version 7200 GS is not very good in a laptop. I got lucky but I also have a least 2g of ram and my system recognizes every bit of it.
geposted Fri 02 May 08 @ 5:53 pm
