Forum: Old versions
Topic: VDJ install stalls copying LCD.ttf
Hi,
I've just download VDJ 5.07.
When I run the install it proceeds normally, I see it copy the exe, the manual pdf and then just as the percentage bars are both at the end it says "copying LCD.ttf" and that's where it stops.
I've left it for 10 minutes, and it just sits there. I had to manually terminate the process with task manager.
VDJ seems to be working, and when I look in the fonts folder LCD.ttf is there, and working. I even tried deleting it and running the install again. Each time is zooms along happily and then just stops dead when copying the font.
Any ideas?
geposted Sat 03 May 08 @ 10:14 am
Did u download it using Internet Explorer or somethin else. I would retry the download from your download center.
