Here's an updated version of the turntablist skin. It features
- new design
- seperate and overlapping waves (at the same time)
- new buttons
http://www.virtualdj.com/addons/skin.html?id=4399
if you like it i will add in video
- new design
- new buttons
geposted Sat 03 May 08 @ 9:37 pm
Any chance of sending me a zip file version so I can use it on my Macbook?
geposted Sun 04 May 08 @ 1:37 am
Like the mod's, Listen2.
You've put some nice features into it mate :)
geposted Sun 04 May 08 @ 6:16 am
Listen2 cool skin m8
geposted Sun 04 May 08 @ 7:52 am
It should have a mac download which includes a .zip file
geposted Sun 04 May 08 @ 8:00 am
Ah, so it does, thanks man. Although the last time I clicked on it I don't recall there being a Mac version. Oh well, got it now.
geposted Sun 04 May 08 @ 8:58 am
I did a last minute update for the clone button, which i think makes a little more sense. check it out!
geposted Sun 04 May 08 @ 11:06 am
Nice one listen2. Thanks:)
geposted Sun 04 May 08 @ 6:07 pm
Used it last night, Really good skin to work with Listen2.
geposted Mon 05 May 08 @ 5:40 am
Nice looking skin, but is there any chance of getting it with differant resolution option for non wide screens?;^]
geposted Mon 05 May 08 @ 8:20 am
Thank you.
I will try and get a 1024 sized up soon. I think i will also go bigger
Video is also in the works!!
- for video mixing how important are previews or is one main display window sufficient?
- or i can have it toggle between , just main video with spinners- and all 3 video previews no spinners.
any other suggestion are welcome.
geposted Mon 05 May 08 @ 8:50 am
Woot!! Thanks man, looking forward to it;^]
geposted Mon 05 May 08 @ 9:02 am
Great skin! Would like to see video implemented into it as well. Video previews are important for me. Would prefer if you made it able to toggle between just main video with spinners- and all 3 video previews no spinners Thanks.
geposted Tue 06 May 08 @ 4:15 pm
Well thats just what i did, i have 3 video displays with an option to choose between spinners or video previews for each channel. I should have it done pretty soon.
geposted Wed 07 May 08 @ 10:23 am
I added a outdoor version if anyone is interested
http://www.virtualdj.com/addons/skin.html?id=4416
geposted Wed 14 May 08 @ 6:09 pm
I love this skin great. BUT I NEED HELP.
I use virtual vinyl and when i use this skin in the top left where the logo's are where it says virtual dj turntabilist mine says VIRTUAL VINYL and is longer and OVERLAPS the turntabilist word can someone fix this minor issue for me? Thanks
geposted Thu 15 May 08 @ 2:10 pm
Also a turntabilist with a video box would be EXTREMLY GREAT!
geposted Thu 15 May 08 @ 2:22 pm
I think Listen2 is working on that.
geposted Fri 16 May 08 @ 12:20 am
Yes it actually done but i am having design conflicts. Its nothing major but i am just trying to decide on the best layout for the video displays. With any luck i can have this upped this weekend.
@djstickittooem send me a screenshot of the upper corner and i will move the text over some.
geposted Fri 16 May 08 @ 9:10 am
Great i appreciate it.
I sent a photo of (GLITCH)
geposted Sat 17 May 08 @ 7:32 pm
