......how to use more than two turntables at once??? becuase i've tried and they dont sync or anything, the songs will be off by a lot and i dont think you can record with two windows open at the same time, so if anybody can explain it step by step to me plz do so.....
geposted Sun 26 Dec 04 @ 3:41 pm
I'm not sure to catch your problem. However I will show you my (basic) mixing technique:
First: Go in config, shurtcut, and add a shurtcut for the SYNC command for each deack.
You can load a song by drag and drop it on a deck.
Same thing for the other deck.
Then you press play on one deck.
When you want to jump to the other deck you:
Press on the shortcut you created before to sync the stopped deck with the playing deck.
Then move the crossfader in direction of the recetly syncronated deck.
Yes you can record with two windows open, depending of your RAM.
(Insted of using shortcut, you can use the Beatlock and the play function, whitch is easier).
geposted Sun 26 Dec 04 @ 10:07 pm
Mixer,
I think you need the full version for this to work. Go purchase the product and try again.
geposted Sun 26 Dec 04 @ 10:20 pm
It will help assuredly ;)
I don't know if the commands I use are available with the demo version.
geposted Sun 26 Dec 04 @ 10:27 pm
