Hi everyone, I'm new to the forums....have not bought Virtual DJ yet but intend to very soon. My understanding is that Virtual DJ software works with Serato hardware at least for audio mixing. What I want to know, IS THIS ALSO THE CASE FOR VIDEO MIXING (can one use Virtual DJ/Cue SOFTWARE with SERATO hardware/Serato Box). By the way I will be using CDJ 1000's or DVJ 1000's with this setup.
Thanks in advance for any & all answers.
geposted Mon 05 May 08 @ 9:18 am
It will work with the SL1 on pc this will allow you to use it as a timecode interface.
If you havent bought it yet why not look at Virtual Vinyl its designed for perfect use with VDJ it also includes a pro license.
geposted Mon 05 May 08 @ 10:21 am
if I already have SSL wouldn't it be redundant to buy VV when all I really need is the VDJ software....or am I mistaken???
geposted Mon 05 May 08 @ 1:06 pm
He said if you hadn't bought SSL already..lol;^]
geposted Mon 05 May 08 @ 1:13 pm
VJGraham wrote :
can one use Virtual DJ/Cue SOFTWARE with SERATO hardware/Serato Box?
yes... The serato box is just a soundcard, and VDJ will work with it, as that.. Just like any other good asio soundcard
So it will output your sound from VDJ, regardless if its audio or video...
And you can control VDJ with timecode, vinyls or cd's, in your case with CDs with the CDJ1000s ;)
If you want to go one step further you can add a midi controller (cheap) or midi capabable mixer (reasonable to expensive), to control crossfade etc in VDJ
Hope that helps ;)
geposted Mon 05 May 08 @ 5:34 pm
