is there a plugin or maybe a software that will remove the music instead of the vocals??
geposted Mon 27 Dec 04 @ 3:37 am
Yes but you must have the full version to download it.
geposted Mon 27 Dec 04 @ 6:48 am
i have the full version. where can i download the plugin?:)
geposted Mon 27 Dec 04 @ 9:50 am
If you have the full version you must encode your serial into your profile.
Then acces the download => plugin section on this website and you ccan download all plugins.
The plugin you want is "Vocal+" but it isn't a "miracle" because the instruments frequencies are often differents. You can adjust by removing some frequencies with an equalizer plugin (32 bands for example).
geposted Mon 27 Dec 04 @ 12:54 pm
