Is there a way to enable VDJ to load long tracks (60 minutes or more) without having it freeze up?
Atomix used to do this very easily. I think it has something to do with the track being analized.Is there a way to take that of so the track just loads.Thanks
geposted Tue 06 May 08 @ 12:31 pm
In options select Max Load to always.
Hope that helps
DJPR1
Hope that helps
DJPR1
geposted Tue 06 May 08 @ 12:40 pm
Thanks but I did that and still no go
geposted Tue 06 May 08 @ 1:07 pm
you have to make sure your machine can handle this load just make sure it's on max load > always. The next thing is that it will take a long load time. I can load a 1g video but it takes a long time to process it in memory.
geposted Tue 06 May 08 @ 1:19 pm
