The product is the best BUT....
The skins should be resizeble with the resoluution of the monitor You use.
So that you can drag the areas bigger for more info in loger lists.
This is a great advantage!
When will this be available? It should be soon.....;)
Good luck, and take it all to the next level.
Jay
Jay
geposted Wed 07 May 08 @ 4:07 am
I agree that this is one MAJOR lacking feature. I don't think that VDJ should leave it up to others to make "skins" to fit your screen. The VDJ Skin that comes with the software should be able to fit all screens. This limitation is completely ridiculous.
For example - Traktor 3 - I can be on my 24" Screen iMac, a 15" Powerbook, or my 15" PC with a high resolution screen and when I enlarge the screen to go full screen - it just fits, perfectly. All fonts, graphics are crystal clear, and it looks excellent. I assumed that all programs were just like this. It wasn't until I actually purchased VDJ that I realized the screen limitations and frankly it's really annoying.
There are so many great things about VDJ that I like, but unfortunately, there are a lot of things that I do NOT like. I wish that they could fix these things - this screen issue is a big downer and should definitely be fixed to work just like other standard software applications. You enlarge the program, it fits to the screen, done deal.
It's too funny - I find myself relying heavily on Traktor still. I guess when I start getting more heavily into Video that will change, since VDJ will be the software to use for that.
geposted Wed 07 May 08 @ 9:32 am
When i use Virtual vinyl, the skin doesnt take up the full screen and virtual dj does the same thing too. It looks doesnt look proffessional at all not to have a full skin. I have rane serato and the skin is always full with no sides cut off. It shouldnt be an option to adjust your native resolution on your screen when the skin should just apply to what ever resolution you have.
geposted Wed 07 May 08 @ 5:59 pm
