After $elling my car, home, girlfriend,soul, myself and taking my college money out of the bank lol i decided to by the Denon DN-HC4500, Denon DN-D6000 Dual CD MP3 Player for the cds, a Denon DN-HD2500 for backup, and finally Denon DN-X500 mixer. My second setup will be the Denon DN-X120 mixer, and two Denon DN-S1200.
what do you think?Any advice before i $pend it all.Alternatives?
geposted Wed 07 May 08 @ 4:23 pm
Yup upgrade to the Pro Version so u get all the support u need to make it all work:)
geposted Wed 07 May 08 @ 5:24 pm
instead of buying the Denon Dn 6000 Get the Denon 4000 or 4500 because it can connect to the HC 4500. The 6000 doesnt work with the HC4500 and it cost alot more.
The back up is using the cd player incase you have problems with the laptop. The HC4500 and the denon 4000 or ( 4500 Or BU 4500 ) is enough already. The HC4500 can controll the 4000 or 4500 cd player and lets you switch between using the pc or the cd player..
geposted Wed 07 May 08 @ 5:38 pm
i heard that when you switch fro using the pc to using cds with the 4500 and bu4500 it freezes, is that true?....well, thats why i decided to buy the 6000 separately
geposted Wed 07 May 08 @ 7:35 pm
Go to the denon forums and do a search on this. I know that denon made an update on the HC4500 and it fixed alot of problems. The Denon 4000 or the 4500 are separate cd players that can connect to the Hc4500. What ever you want to buy is up to you but software always get updated and bugs always get fixed.
Here is The Denon Update from the denon website
New & Current Plug In’s as of February 2008 (Sys 1005)
-Added Windows Vista support
-Added New Preset, Item #6 > “Jog Trns Int” (Jog Pulse Transfer Interval)
Previous Plug In’s also Included with current version
-Enabled CD control when DN-HC4500 is not connected to a PC
-No instructions required, software improvement
-Added Leopard MAC OS (Version10.5) support
Added ALL (0x7F) to the MIDI channel of the MIDI configuration commands.
Notification of Misprint in Operating Instructions (page 15, MIDI List)
-A1 Dimmer LED 0x3C -> 0x3E
-A2 Dimmer LED 0x3D -> 0x3F
DENON DJ ASIO Driver update (V1.01)
-Added Windows Vista/XP SP2 dual boot support
geposted Thu 08 May 08 @ 12:57 am
Look here in the denon forum
http://www.denondjforums.com/viewtopic.php?f=31&t=8950
geposted Thu 08 May 08 @ 1:10 am
