I am using Virtual DJ Pro for a restaurant / bar, and we are experiencing a crash where VDJ will go into a stutter (we did not hit stutter) and then lockup. We then have to do a manual restart and it is beginning to become very annoying. Does anyone have any thoughts, hints, tips, or tricks that might help me out. I am learning all about Virtual DJ as I go so any help will be great!
geposted Wed 07 May 08 @ 5:32 pm
Well, what are the specs of the computer. Next what are doing before the lockup accures. Can you send us the crash report under documents, VDJ
geposted Wed 07 May 08 @ 5:40 pm
I can't seem to find the crash report. What kind of file type is it? I really don't know what I am looking for either.
geposted Mon 12 May 08 @ 10:37 pm
You can find the file under My Documents/VirtualDJ/Crashguard report.txt
Also, post your specs (CPU, memory, video, etc.). You will get more useful advice that way.
geposted Mon 12 May 08 @ 10:45 pm
There isn't a text file in that location. Could it be somewhere else? Here are the specs (let me know if you need more spec info)
Dell Precision
Windows XP Pro
Service pack 2
Quad-Xeon CPU
2.3 ghz
2 gigs of ram
1.5 TB hard drives
Dell Precision
Windows XP Pro
Service pack 2
Quad-Xeon CPU
2.3 ghz
2 gigs of ram
1.5 TB hard drives
geposted Tue 13 May 08 @ 4:27 pm
rob
if you have short cuts enabled you may have inadvertently hit a short cut key... just a thought and something to check out...
Tayla
Tayla
geposted Tue 13 May 08 @ 6:49 pm
You still haven't explained what you were doing in the process of DJing that the crash occured. We might be able to recreate or understand better as what the problem is.
geposted Tue 13 May 08 @ 7:59 pm
uninstall and reinstall
geposted Tue 13 May 08 @ 9:35 pm
Here is the crash report:
Crash ID=004726a1 (date=802051245, version=5.0 rev.6, build=506, thread=Main, dump=8b421451, excode=c0000005 (0,14))
Crash ID=7c9c6f90 (date=802251044, version=5.0 rev.6, build=506, thread=Main, dump=65007200, excode=c0000005 (0,ffffffff))
Crash ID=7c9c6f90 (date=803031056, version=5.0 rev.6, build=506, thread=Main, dump=65007200, excode=c0000005 (0,ffffffff))
Crash ID=0046c8e0 (date=803040031, version=5.0 rev.6, build=506, thread=Main, dump=8a018802, excode=c0000005 (0,6c6c616d))
If I uninstall and reinstall will I loose my Virtual Crates?
geposted Wed 14 May 08 @ 3:51 am
I would wait till someone from the team gets back to you on this issue.
It's worth knowing why it's crashing in the first place.
geposted Wed 14 May 08 @ 9:07 am
Are you still using V5.0.6 or is it old crashes?
geposted Wed 14 May 08 @ 4:25 pm
I am still using V5.0.6
geposted Wed 14 May 08 @ 9:09 pm
Can you use a tool like TagScanner to verify that you don't have a corrupted file.
http://www.xdlab.ru/en/
geposted Wed 14 May 08 @ 11:46 pm
I am hesitant to DL a program that I have never heard of. Has anyone else used this program? I don't believe it is just one file that could be causing the crash.
Does anyone know if I will loose my virtual folders if I uninstall and reinstall VDJ?
geposted Thu 15 May 08 @ 7:42 pm
Yes I can verify this program..I have used it before it is solid.
geposted Thu 15 May 08 @ 7:44 pm
