Im thinking about getting some time code records to use but im curious, what else would i have to get besides the records? and how do they work?
geposted Fri 09 May 08 @ 4:51 pm
Hi
You need 2 stereo inputs sound card like Hercules MK2, Maya 44 or ESI U46DJ. You connect turntables to line in on sound card and that's it.
You will need VDJ Pro off course, you can try TCV on demo version also.
geposted Fri 09 May 08 @ 7:41 pm
Don;t use serato vinyls - they cause crashes
geposted Fri 09 May 08 @ 8:28 pm
Well I just got a bcd2000 today and had serato tcv and they work pretty well,the only thing is that the pitch is off a bit.With vdj 5.0.7 demo the bcd2000 is working and sounding quite quality.I am shocked after hearing so many downfalls.Go with the virtual dj time codes definitely.
geposted Fri 09 May 08 @ 10:24 pm
