Has anybody downloaded it, it's showing on my windows Update, but I would like to see if anybody has installed it on their Gig machine, before I install it on my gig lappy.
Thinking about installing it on my home PC first though
geposted Sat 10 May 08 @ 11:17 am
Basicaly it just adds the previous updates , server 2008 support , new security patches and a NEW PIRACY CHECKER!
geposted Sat 10 May 08 @ 12:17 pm
Cheer's Simon.
Just installed it on my home pc, seem's ok.
geposted Sat 10 May 08 @ 1:23 pm
geposted Sat 10 May 08 @ 2:13 pm
I downloaded SP3 onto my machine - I'm taking it for a spin tonight (well, I'll play for a 3 or 4 hours at home) - I'll let you know how it goes.
geposted Sat 10 May 08 @ 4:20 pm
My XP SP3 worked flawless 4hours yesterday evening. It seems okay, SP3 has nothing really new...
My Vista Machine (SP1) has been quite stable too when using analouge output. I have a ExtremeMusic card but "cannot" use SPDIF out without severe leaking between the channels. Its my back-up machine but I would appreciate if Atomix woud fix this in 5.1 (6.0). The Soundquality is (much) better when sending the signal in digital form to the amp.
Keep spinning!
Keep spinning!
geposted Sun 11 May 08 @ 4:28 am
As I said before SP3 brings all security patches and nothing new for VDJ. Compatibility should be the same.
geposted Sun 11 May 08 @ 6:57 am
