I want to use my headphones because it´s an important part of mixing. But it don´t work! Can someone tell me how to connect my headphones with VDJ? Maby my problem is my old-soundcard with only one connection? I need help very quick I hope someone will tell me about my problem! This are my institutions:
- Inputs: None
-Outputs: Headphones
-Soundcard(s): Mono Seperated
- Inputs: None
geposted Sat 10 May 08 @ 3:13 pm
This topic has been discussed many, many many times.....please utilize the search feature and you will find your answers there...
geposted Sat 10 May 08 @ 3:41 pm
yo dude il do the best i cn to help yu .... as u said it yoself the problem is your sound card with one output slot .... so i sujest u get yourself a new n better sound card or u cud use two sound cards with single output slots .... one for the earphones and one for sound output....adjust yo card configuration n ul be on ya way !!.. gud luck
geposted Wed 14 May 08 @ 5:11 am
