All have the versions of the virtual dj and I noticed that you removed the option of the manual automix will be that he/she has as using in the version 5 to order answer to the email
geposted Mon 12 May 08 @ 11:39 pm
What????? Try a better translator.
geposted Mon 12 May 08 @ 11:59 pm
manuel ottomix? press alt+space and pray
geposted Tue 13 May 08 @ 4:25 am
I will try to be more specific, in the version 3.4 with original skin is enough to carry the music or video and to click in the automix and him finishes automatically, in other words, without putting the music in the playlist, in the version 5.7 it doesn't execute, only in the playlist
geposted Tue 13 May 08 @ 7:39 am
excuse me for the translator
geposted Tue 13 May 08 @ 7:41 am
That is because the AutoMix button at the top is now for starting the automix of the playlist.
You need to create a shortcut for the mix_now action. As wildcountryclub mentioned above - you can assign it to the Alt+Space key combination.
There are other skins for download by licensed users that have the Mix_Now capability assigned to the skin button.
geposted Tue 13 May 08 @ 8:28 am
Using keyboard shortcuts you can actually assign the space bar to do two functions at once.
MIX NOW and START can both be assigned to the space bar and then use it to start and mix the next (other) deck as it mixes to it.
You won't find this in any instructions ... I sort of stumbled into it working.
geposted Wed 14 May 08 @ 10:44 am
John C,
What you are talking about is called a shortcut Macro (assigning multiple actions to a key), and is covered in the manual.
Regards
Regards
geposted Wed 14 May 08 @ 11:34 am
Macros ... yep .... wasn't aware it was in the manual to do explicitly what it was I suggested, but it's good more know you can do this.
Thanks.
Thanks.
geposted Thu 15 May 08 @ 8:14 am
