I downloaded VDJ yesterday and it worked perfectly. Today I can't get the turntables to play. I can't think of what I did differently yesterday. ANY SUGGESTIONS?
geposted Tue 13 May 08 @ 8:24 am
And yes... I did press play.
geposted Tue 13 May 08 @ 8:25 am
Can you explain more, what happens when you press play on deck? Did you changed Sound card or something? Which OS do you use?
geposted Tue 13 May 08 @ 9:11 am
Nothing happend. The turntable didn't start playing.
I opened and closed the program several times and now it's up and running.
But this has me wondering if I buy the software...am I going to have similar problems?
geposted Tue 13 May 08 @ 11:09 am
No, you will not, as I use VDJ often and it never happened to me, must be some glitch on your machine. We can find out what it is.
geposted Tue 13 May 08 @ 11:28 am
I gotta question...
If I buy VDJ, which I probably will, download it onto my laptap...then later change computers. Wouldn't it be better to get the program on CD as opposed to downloading it?
geposted Tue 13 May 08 @ 11:43 am
You could buy Numark Cue, which is the same software, but with the Numark branding. That comes in CD form.
Or you could download VirtualDJ, store it in a folder, then burn it to CD from that folder.
geposted Tue 13 May 08 @ 11:47 am
Thanks!
geposted Tue 13 May 08 @ 12:33 pm
So is Numark Cue just like Virtual DJ?
geposted Tue 13 May 08 @ 12:34 pm
Numark Cue is the same as VirtualDJ, but named differently. There might be 1 or 2 very minor changes, but it's the same software.
geposted Tue 13 May 08 @ 12:43 pm
