Hi everybody,
I'm trying to resize a skin (1280x1024) to 1024x768. I'm downloaded VDJ Skin Resizer, I followed instructions and I placed the .rar file with the .xml an .bmp file in the Skins folder. The VDJ Skin Resizer shows no error during the resizing procees. But when I open VDJ the skin doesn't appear on the menu. And when I put the resized files in the original .rar file (2 skins in the same .rar) an Error message is displayed.
What do I do?
Thanks
What do I do?
Thanks
geposted Thu 15 May 08 @ 9:03 am
The Skin re-sizer really only works well if the resizing is of a matching format. Example: It cannot re-size a square skin into a rectangular one. Your best bet might be to try a different skin. What skin are you trying to resize??
geposted Thu 15 May 08 @ 9:08 am
Pioneer_CDJ_1280x1024_DJM_Mixer
I downloaded it from the VDJ website.
geposted Thu 15 May 08 @ 9:12 am
I find it ridiculous that not every skin fills up your screen depending on what skin you use. Rane serato no matter what native resolution you have it on. It fills up the screen completely. This is supposed to be a proffesional software and by not having the screen filled up, it doesnt look proffessional at all. I dont see how a company that has been around longer than serato still have problems with skins, time codes etc and rane serato, a company that's been around for a short time make so much splash and work flawless.
geposted Thu 15 May 08 @ 8:22 pm
