Forum: Music discussion - Topic: MP3 quality when transfering files
Talk about music here. Of course no illegal exchange is allowed.
VirtualDJ Forum
Music discussion
MP3 quality when...
Autor - Topic: MP3 quality when transfering files -
mzack
Professional edition user
Posted Thu 15 May 08 @ 10:21 am
When transfering MP3's from hard drive to external to another computer etc, and back and forth....
Does the quality of the file get compromised??
jimmy b
VIP Member
Posted Thu 15 May 08 @ 12:44 pm
Good question, I've always wondered that.
I've come to the conclusion that it doesn't but I would like to know.
discjockeydoc
Experienced pro user
Posted Thu 15 May 08 @ 1:27 pm
I don't think so.
It's not like recording from progressive video tapes instead of a master, for example, where the quality of the recording quickly degrades from one to the next. Your tracks aren't actual recordings on your hard disk. They are data files.
jimmy b
VIP Member
Posted Thu 15 May 08 @ 1:48 pm
That's what I thought Doc.
DJ-ALF
Moderator
Posted Thu 15 May 08 @ 1:52 pm
I don't think so. Your tracks aren't actual recordings on your hard disk. They are data files.
Well explained.
So the answer is no, you can copy without any loss in quality.
mzack
Posted Thu 05 Jun 08 @ 11:55 am
Thanks everyone...
Sorry for the delayed post!
mzack
discjockeydoc
Posted Thu 05 Jun 08 @ 4:26 pm
Happy to help ;)
Paz75
Posted Mon 09 Jun 08 @ 11:04 am
Loss of quality cannot be caused by transfer errors but can happen prior to transfer. Unfortunately there is a constant problem of your hardrive to have crosslinked files which occur through wear and tear, heat, dropping, etc. The mp3 standard is such that it behaves like CD Audio. Any data which it cannot read, it will drop. This can result in aliasing and/or artifacts. The good thing is that you usually wont notice unless many consecutive bits get damaged.
However, the above does not have anything to do with copying. File copies on a filesystem use CRC checksum which is a system that makes sure that the data which is copied is exactly as the source.
The point is that your files likely are degrading ever-so-slightly over time.
One way around this is to have separate physical hard-drives for storing critical data and having multiple copies. Back everything up on a drive which never gets used except to write new files.
khr0nic
No license user
Posted Mon 09 Jun 08 @ 11:25 am
The answer is yes. This person explained it. ^
khr0nic
No license user
Posted Mon 09 Jun 08 @ 11:26 am
No I change my mind the answer depends on certain situations, lol.
DJ-ALF
Moderator
Posted Sun 15 Jun 08 @ 5:51 pm
The answer is still no, if your copy gets damaged, you can't copy it at all.
You are saying that files recorded on a CD/DVD or HD will lose quality in time? So NOT true. It can be damaged, but it will play the same as the day you recorded it or it won't play at all. Simple as that.
Paz75
Posted Mon 16 Jun 08 @ 10:47 pm
m8, please check your facts. there is a difference between CD/DVD and HD so dont lump them together. ask any data admin, they dont typically use spinning media for backing up data and prefer tape still because CD/DVD have a limited shelf life of 5-10 years max. You can buy special coated disks that are tested (theoretically) for 100 years but theyre really expensive. The disk coating is a type of metal which oxidizes slowly with time. this means the holes burned in binary configuration will expand with time and eventually the laser wont differentiate between a 1 and 0.
secondly, because the CD reading format for audio is different than data, this means it will drop unplayable bits which degrades quality to an extent. like i said, consecutive read errors result in noticeable loss. for data, this is much less. if you burned mp3 files, the CRC checksum is applied and then your only worry is what i said before about disk oxidation as well as physical media damage (scratched disk).
anyhow, this is OT now. the subject matter is simply about copying. no, copying doesnt change quality, end of story. but there are more things to consider like was the source file damaged to begin with? the only storage state that currently is forever (AFAIK) is the new solidstate drives. the rest, including hard drives need to have data rotated ever so often to prevent data loss.
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
