WHeni record my mix i get a fairly loud humming sound in the background. iamI It seems llike the recording program is recording the timecode sound aswell.
Is there any way to fix this?
geposted Fri 16 May 08 @ 11:51 pm
I was just looking at styluses and cartridges then and noticed digitrack styluses which are meant for digita dj timecode vinyls. Would these help In cutting out the noise?
geposted Sat 17 May 08 @ 3:42 am
Humming noise. That was meant to go in my last message but my computer stuffed up.
geposted Sat 17 May 08 @ 4:08 am
one time I tried recording from my laptop while it was
plugged in(charging), and I got the humming noise-
I unplugged it and used the battery alone and the noise
stopped
geposted Sat 17 May 08 @ 3:23 pm
It might be a Ground Loop problem, did you grounded your TT's properly?
geposted Sat 17 May 08 @ 5:29 pm
