Forum: Old versions
Topic: Oxygen 8
Can i use my M-Audio Oxygen 8 and set it up to control certian paramaters of the mixer... because this moving one thing at a time with the mouse isnt cutting it....
geposted Sat 17 May 08 @ 1:59 pm
I think you can as it is a MIDI device, you can try to map it yourself, go to "Config>Remote Control>General MIDI>Config".
Anyone figure this out? I dont see those options???
Those options won't be there if you're using the home free version.
Keith
These options aren't available any more because they are obsolete (This topic is from 2008 and over 4 years old!)
In the latest version, MIDI controllers can be accessed CONFIG -> Mappers but usage is limited to 10 minutes at a time in VirtualDJ Home FREE.
To use MIDI controllers for more than 10 minutes, you will need to purchase the full VirtualDJ Professional: https://virtualdj.com/buy/
For info on how to map a MIDI controller, please see our FAQ pages: https://virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
[Old topic from 2008 closed]
