Hey, does anyone know how I can extend the record time to burn to CD?
I'm trying to create my own .mp3 CD's and have about 90 songs saved in my "Playlist" and ready to burn to CD. However, as I am recording and mixing the next song to start before the current song ends, it stops recording on it's own. Only about 2-3 songs were recorded to my hard drive. How can I extend this recording time to continue and record from "Master" and save to my hard drive so I can later burn it on to a CD?
Thanks for your help!
geposted Sat 17 May 08 @ 2:35 pm
so, I guess nobody knows...?
geposted Sat 17 May 08 @ 3:10 pm
It could be that u have not enough memory on ur HD. Verify what is ur HD size n how much is left. If u have multiple drive or external just change the recording location to the one that have alot of memory left.
geposted Sat 17 May 08 @ 5:04 pm
No, this is not the case. I still have 58GB of free space on my HD. There should be a setting for VDJ where I can increase the recording time, I just don't know how to change this. I've also read the instructions manual and found nothing.
Any other suggestions? Anyone.....?
geposted Sat 17 May 08 @ 6:48 pm
Which version do you use?
geposted Sun 18 May 08 @ 9:02 am
Sorry for double post... I begun to think that maybe I should have posted in Technical Support instead of here.
I'm using version 5.0.7
geposted Sun 18 May 08 @ 5:34 pm
DJ ALF,
I
am
using
version
5.0.7.....
I
am
using
version
5.0.7.....
geposted Tue 20 May 08 @ 3:14 pm
Ok, ok, I see that ;)
Is it demo version? You have something overlooked in your setup. I don't know reason why it won't record like it should be, all fine at my PC.
geposted Tue 20 May 08 @ 3:51 pm
Do you have the split on fade feature checked? or auto split?
geposted Tue 20 May 08 @ 4:11 pm
i'm not sure...how can I find out?
geposted Sat 24 May 08 @ 7:48 am
Go to Record>Config>Split in Multiple files > disable.
geposted Sat 24 May 08 @ 9:23 am
OK, I did that in "Record" tabs "Record file". Now willl this disable the "Split in Multiple files" for "Burn CD & Broadcast" Also?
Thanks!
Thanks!
geposted Mon 26 May 08 @ 9:29 am
OK, I have disabled this....
Question...can VDJ burn directly to a blank CD instead of hard drive then to CD?
Thanks!
Thanks!
geposted Mon 26 May 08 @ 9:43 am
