Ok, until I find out the cap on how much assistance they will provide me I'm only looking at the most important things. So I'm starting my list and totaling it out over actual costs ($7000) to provide extra for acceseries and portable furniture. Anyway, I wanted to get some inputs on my list so far.
Carvin PA: https://www.carvinguitars.com/products/single.php?product=SYS10
Lighting: http://www.musiciansfriend.com/product/Stage-Lighting-System-3?sku=805031
For Karaoke and gigs with tighter space: http://www.musiciansfriend.com/product/Numark-KMX02-Karaoke-Mix-Station?sku=631000
HP d5000t Desktop PC with specs: Operating system Upgrade to Genuine Vista Ultimate with Service Pack 1 (64-bit) edit
Processor Intel(R) Core(TM) 2 Quad processor Q9550 (2.83GHz) edit
Memory 8GB DDR2-800MHz dual channel SDRAM (4x2048) edit
Graphics Card 512MB NVIDIA GeForce 8800GT, 2 DVI, TV-Out edit
Networking Wireless LAN 802.11a/b/g/n & Bluetooth(R ) edit
Hard Drive 1.5TB 7200rpm SATA 3Gb/s two hard drives (2x750GB) edit
Primary CD/DVD Drive Blu-ray writer / HD DVD player & Lightscribe SuperMulti DVD burner edit
Front Productivity Ports 15-in-1 memory card reader, 2 USB, 1394, audio edit
TV & Entertainment Experience No TV Tuner w/remote control edit
Sound Card Integrated 7.1 channel sound w/front audio ports edit
Security Software Norton Internet Security(TM) 2008 - 15 month edit
Productivity Software Microsoft(R) Works 9.0 edit
Keyboard and Mouse HP keyboard and HP optical mouse edit
Your additional options:
Click edit to modify. NOTE: These items are in stock and will ship immediately.
Monitor HP w1907 19" LCD Wide Flat Panel Monitor
And video projector: http://www.circuitcity.com/ccd/Search.do?Ntt=IN1B1BUNDLE&keyword=IN1B1BUNDLE&N=90000141+&c=1&cm_re=main%20marquee-_-Take%20it%20with%20you-_-InFocus%20Projector%20Bundle
I'd probably add a couple sm58 mics as well;^]
geposted Sun 18 May 08 @ 8:30 am
Almost forgot, that list should also include a 2 year plan with bluehost to build my website;^]
geposted Sun 18 May 08 @ 9:00 am
Good list there Timmy apart from
You may find difficulty in getting drivers that support 64 bit Vista
And
Not the dreaded Norton, I would go for the Mcafee Security suite, personally.
Good luck mate.
geposted Sun 18 May 08 @ 9:43 am
Don't worry, I'm not gonna use the Norton, it's just automaticaly included with the package, I've got a free subscription to Mcaffee through my Comcast cable & internet subscription. The only drivers I can think of that I'll need will be for my delta 1010lt sound card, my RMX and my Korg Padkontrol (also use a M Audio Radium 49 but it's connected through the delta midi in). I'm pretty sure all three have drivers that support 64 bit, I'll have to look into that again to make sure. Hopefuly this PC won't go obselete anytime soon, that's my thinking anyway..lol';^]
geposted Sun 18 May 08 @ 9:50 am
