Forum: Wishes and new features
Topic: Played songs
It would be nice that VDJ keeps track of all played songs.
I'm not using the internal database, because that doesn't suit my way of finding my records.
I have a fast search proggie, that helps me find my songs, and then drag drop them from in that prog (or windows explorer) onto VDJ.
So if these from external dragged songs are kept in a list, would be a nice feature.
Thanks.
geposted Wed 29 Dec 04 @ 3:27 pm
They are saved to a plist that is saved under your playlists. You can then take that saved file and open it in word and have a full playlist with times. Believe me it just saved me when a client complained about one of my dj's for a recent christmas party. I reviewed the playlist and debunked a lot of the complaints when this DJ never once received a bad grade under me....
Still available but in the VDJ browser -> playlists.
Your wish was fulfillled.
Vantinedj...interesting to confont your client with the playlist of the evening!Good idea
I am sure this will keep the a-holes in check
You can also bring a webcam and film small clips of the evening
Andre
Hey thanks you all. I saw some lists of the previous days I was playing. But today I'm not succeeding in having this list automatically created ?
Can somebody explain, how the creation and saving is triggered?
Tried already closing and opening VDJ, but no luck....
Trief with free playlist, but no luck either.
Thanks in advance.
Ensure to have your statistics option activated.
Strange that your previous playlists were saved and that once you've seen them the new ones aren't saved. What happened ? A crash ?
Don't recall of encountering a crash...
and what in case of a crash, could there have been a setting trashed somewhere?
And can you tell me how I turn on the statistics?
BTW, found the history.txt, which as well keeps track of the played songs.
But I was talking about the m3u files in the folder playlists below \Program Files\VirtualDJ.
And besides of this... it would be nice to have it integrated within the GUI of Virtual DJ.
- Some crashes has several strange secondary effects.
- To turn on statistics: config => general => statistics
OK, thanks.
Just went into the general tab, but don't see the statistics option.
I am using VDJ 2.06 Full version.
Only options I see are:
- Multi Users = Enabled
- Security = Ask
- AutoUpdate = Enabled
- Charts = Enabled
- Tooltip = Enabled
- Max Load = 10 mn
- Scrolling = Normal
- Disc = 45rpm
- Pitch Range = -34% to + 34%
Nothing that looks/sounds like statistics, like what you are referring to.
Can you please help out on this?
Maybe option disappreared due to crash, uninstall/reinstall?
or are you referring to a different version?
Thanks.
My computer/ (Your drive letter)/Program Files/VDJ/Playlists Look for the date you want (as ong as you didn't delete them. Right click. Click open with - use wordpad or note pad. Comes out better in Microsoft Word if you have it...
V
Thanks VantineDJ, those I already found.
But for some odd reason, these are not created anymore since the last days...
I just open up VDJ, drag a few songs to the desks and play them.
To me the m3u files should be created automatically, but this isn't the case.
Any help is welcome.
Sorry yvesmk i have a french version; I told you about the "charts" option.
But it's possible I'm wrong and that this option is not the good ont for the playlists. I have to check.
I think playlists are created only when exiting VDJ.
I'll check.
Thanks for checking already, I'm gonna have a look.
Strange:
- I disengaged the charts option, try to play some tracks => no playlist automatically created
- I re-engaged it an dplayed some tracks => no more playlist !
I'll ask some details to the team and tell you the result.
Nice, it looks you are able to reproduce the problem I am talking about... thanks for the help already.
