Topic: need help for set up - Page: 1
ntmusicHome userMember since 2008
hi
this is what i have
equipment
1x DJM800
2x CDJ1000MK3
1x herc MK2
2x laptops
2x time code cds
when all set up with time code it works ok but when i turn time code off and put audio cds the herc or something can not handle the sound and it cuts out
i dont mind getting rid of the herc and buying a new sound card
i think i have 2 options
1x the long way with lots of cables and a switch type box to switch to herc and switch to bybass it
2x buy a new sound card that will work
please any help
geposted Mon 19 May 08 @ 11:19 am
DJ-ALFPRO InfinityModeratorMember since 2005
Which version of VDJ do you use?
geposted Mon 19 May 08 @ 11:28 am
jimmy bPRO InfinityMember since 2007
Have you thought off Looking Here. It has a bypass switch/Knod you turn in order to play "normal" vinyl or CD. It would work with VirtualDJ.
Also a License copy of VirtualDJ would help.
geposted Mon 19 May 08 @ 11:31 am
i have and old copy of vdj but im going to buy the latest pro
i wonder why the herc can not cope with switching from time code to audio
geposted Mon 19 May 08 @ 11:34 am
also with the M Audio Conectiv i would not need the herc
geposted Mon 19 May 08 @ 11:36 am
If you want a new soundcard to do it, buy something like Virtual Vinyl wchich has bypass outputs.
If you want the best cheap sollution use splitter cables, no need for a bypass box when splitters work perfectly fine & costs under $10 where I live;^]
i think i will go for the new sound card as this will be not a fixed set up will be moving around clubs
geposted Mon 19 May 08 @ 11:38 am
not to sound stupid but is the M Audio Conectiv a sound card so i would not need the herc
geposted Mon 19 May 08 @ 11:43 am
Mines not a fixed setup either, splitter cables don't infringe on mobility at all. However, the mk2 & the rmx aren't exactly the best sound cards for timecodes, so a new sound card could be a wise investment;^]
geposted Mon 19 May 08 @ 11:45 am
as far as i know i need 4 ins and 4 outs could u recommend a good one
geposted Mon 19 May 08 @ 11:47 am
Yep, you can do away with your herc, and use the M Audio Conectiv as your soundcard, it has the inputs and outputs you need for timecode.
geposted Mon 19 May 08 @ 11:48 am
You could always go with virtual vinyl package, it has soundcard with bypass outs (yes, with 4 in 4 out), timecodes and the pro software. Haven't heard enough about the m audio to say much about that one;^]
geposted Mon 19 May 08 @ 11:51 am
but it might do what ther herc did
2 cdjs
l l
time code audio cd
l l
sound card
l
mixer
l
amp
think thats right
geposted Mon 19 May 08 @ 11:52 am
but it might do what the herc did
............2 cdjs
........l................l
time code......audio cd
..........l............l
..........sound card
.................l
..............mixer
.................l
..............amp
think thats right
geposted Mon 19 May 08 @ 11:55 am
I would think the virtual vinyl soundcard would have much fewer problems as it is tailor designed for VDJ, seems to be alot happy users with it. Alot of performance issues though depends on your computer specs;^]
geposted Mon 19 May 08 @ 11:58 am
i have 2 laptops to do it with
1x mac 2.1GHz core 2 10.4 and 10.5 1gb ram
2x windows - 2GHz xp sp2 512 ram
geposted Mon 19 May 08 @ 12:16 pm
geposted Mon 19 May 08 @ 12:17 pm
VIRTUALVINYL will this let me swap from time code to normal cd and work with out doing any unplugging
geposted Mon 19 May 08 @ 12:19 pm
Yes, I opt for the splitters for that because I've already got a good card for timecodes on my desktop (delta 1010lt), but it's to my understanding that the bypass ports in the rear of the VV card go straight to your mixer, so you'll use a total of four mixer channels, two for regular cds and two for timecodes. The same as with splitters but without splitters;^]
More on VV: http://www.numark.com/virtualvinyl
geposted Mon 19 May 08 @ 12:25 pm
not sure what you mean
dose it split them up
2 cd decks go in to VV --- 4 phonos (2 left and 2 right) then from the box 2 time code come out to mixer and 2 come from cdjs them self and go to mixer
geposted Mon 19 May 08 @ 12:32 pm
71%
