Hi there, i am considering buying this USB mixer but cannot find too much info for it? The equipment is 'DJ-TECH PROFESSIONAL USB KIT-10' what I want to know is, is it compatible with virtual dj? if any one has any info it would be much appreciated!
Thanks
here is a link to an image of the product: http://www.soundlightuk.com/Ebay/dj_tech_usb_mixer_rear.jpg
Thanks
geposted Mon 19 May 08 @ 4:10 pm
It might be if it has MIDI option.
geposted Mon 19 May 08 @ 5:42 pm
That mixer's USB ports are for mixing music straight from a MP3 player. Look at the USB ports - they are backwards.
geposted Mon 19 May 08 @ 7:17 pm
Good call Cstoll!
how about this hardware :
http://www.mixman.com/products/hardware.html
Cheers, Phil
Cheers, Phil
geposted Tue 20 May 08 @ 8:46 am
I think it is dedicated to it's own producer software and does not support MIDI option.
geposted Tue 20 May 08 @ 12:20 pm
iniquityclothing wrote :
Good call Cstoll!
Cheers, Phil
Cheers, Phil
there is a way to convert this to a midi device... its somewhere on the forum you gotta search it.
geposted Tue 20 May 08 @ 1:55 pm
I use to have the dm2, not with VDJ but just with the mixman software. It was hardly worth the $30 I payed for it. Cheap plastic buttons that would get stuck under the plastic chassis when pressed in, and not very well built at all. I thought the mixman company went under, kinda surprised to see them still around;^]
geposted Tue 20 May 08 @ 2:51 pm
Still stuck with what to buy, how about this one, cannot seem to find google info on it, or if I do the product with the same name is completely different to the one im looking for,
heres the spec;
Take your DJing forward into the digital world with the complete computer based DJ solution which includes the X-Session USB DJ mixer, Ableton Live XS digital audio workstation and Arturia Storm XS virtual studio.
Designed for the new breed of DJ to mix on PC or Mac. X-Session has a classic full-size crossfader for cutting and scratching, 16 assignable rotary controllers for pitch-shifting, tweaking Delay/EQ/Filter/Distortion/Flange, 10 assignable buttons for triggering loops, grooves, digital effects and killing tracks plus stacks more cutting-edge features which will take your DJing into the future.
This USB controller also provides finger-tip control for a whole host of popular software plug-ins and virtual instruments, eliminating the frustrations of trying to use a mouse. Fast and precise control is provided by the 16 fully assignable high resolution controllers. Each of these controllers can be assigned to a different MIDI channel which means that multiple plug-ins can be controlled on separate channels. Synths and modules can also be controlled via the standard MIDI Out socket. X-Session has 10 memory locations for storing your settings. These are non-volatile too, so everything is saved even when the unit is powered off.
Main features
*Scratch and mix using the full-size crossfader
*Trigger loops and digital effects with 10 assignable buttons *Tweak Delay/EQ/Filter/Distortion/Flanger and pitch-shift using 16 assignable rotary controllers *Perfect for real-time control of software plug-ins and virtual instruments *Kill tracks then slam them back in at the touch of a button with the unique controller mute function which allows you to mute the output of all controllers, position them to the new value you want, then slam them back into the mix. *Independent channel assign for each controller *Provides USB to MIDI interface with standard MIDI OUT socket *USB Class compliant (USB cable plus PC and Mac drivers included) *No drivers required in Windows XP or Mac OSX *For use with PC, Mac or other MIDI hardware *10 memory locations for storing your settings *PC librarian software included
Controller Requirements:
PC/Mac or MIDI hardware with USB or MIDI In.
<img src="http://i17.ebayimg.com/01/i/000/f4/08/8787_1.JPG"></img>
heres the spec;
Main features
geposted Thu 05 Jun 08 @ 7:30 am
Hi Folks, I am considering Hercules MK1 console, does it have an onboard soundcard for dual output? Thanks
geposted Mon 09 Jun 08 @ 1:46 pm
i wrote a plugin to support the dm2 on pc , it is a good toy but is not suitable for live work.
geposted Sat 14 Jun 08 @ 4:17 pm
