Forum: Old versions
Topic: maya 44 VS gigaport
is a gigaport which you use with pcdj the same as the maya 44 do they do the same thing.or what am trying to ask is can the gigaport use with virtualdj
geposted Wed 29 Dec 04 @ 8:44 pm
Maya has four mono outputs (two stereo) and four mono inputs (two stereo) (for turntable integration). Gigaport has eight mono outputs (four stereo) no inputs. Great for putting yor sampler on a seperate channel as I have it set up. I do have both cards but only use the gigaport. Works best for my line of work.
But if you need Timecode (vinyl/cd), maya is the answer.
(for samples use the onboard)
