Is there a way to add a security code, encode to files to my external hard drive in the case of theft?
I believe PCDJ encodes the files to only work with your PCDJ and if files are stolen, they wouldn’t work on another computer.
geposted Tue 20 May 08 @ 10:06 am
I think there is no such option in VDJ.
geposted Tue 20 May 08 @ 10:14 am
no there isn't but is there any other way to secure the drive besides keeping it in my back pocket
geposted Tue 20 May 08 @ 10:36 am
Just had a quick google around, and I've Found This.
Might be worth looking into, and it looks free.
geposted Tue 20 May 08 @ 10:55 am
Actually, that looks appealing.
geposted Tue 20 May 08 @ 11:00 am
I thought so too fatkatz,
A lucky hit I guess.
geposted Tue 20 May 08 @ 11:11 am
jimmy shoots... he scores.
good find, thanks!
good find, thanks!
geposted Tue 20 May 08 @ 12:15 pm
Why dont you just use the Encrypt feature built into Windows XP?
geposted Tue 20 May 08 @ 1:56 pm
geposted Tue 20 May 08 @ 2:30 pm
I have vista. Will that make them unusable it taken off the drive or drive will not open without the computer it's encrypted on
geposted Tue 20 May 08 @ 2:32 pm
paulettecerra wrote :
[quote=CanSpoilU]Why dont you just use the Encrypt feature built into Windows XP?
Will the files be unable to be altered or removed and used on another computer without administrator password?
geposted Tue 20 May 08 @ 3:06 pm
I've found this
http://www.truecrypt.org/
Free open-source software!
Cheers
Cheers
geposted Wed 21 May 08 @ 3:49 am
