I can't find my original posting on the setting for PAGE FILE settings. I guess it was listed in the original website before it was changed. Anyway, I would like to know the rule for setting the Page File amount. This is the last thing I would like to do optimize my system. I reset everything back to factory because of poor system performance issues due to system updates.
geposted Wed 21 May 08 @ 12:48 pm
http://tweakhound.com/xp/xptweaks/supertweaks5.htm
Handy info :)
Handy info :)
geposted Wed 21 May 08 @ 4:35 pm
Page file should be set to 1 and a half times the amount of physical ram that you have in your system. So if you have 1 gig of RAM your page file would be roughly about 1.5 gig.
geposted Wed 21 May 08 @ 9:15 pm
If you have a lot of ram memory you can disable page file, that's what I did (1,5Gb, audio use).
geposted Thu 22 May 08 @ 7:32 am
isn't it better to get more ram or get more memory on your graphics card than to increase the size of the paged area ??
geposted Thu 22 May 08 @ 8:26 am
Yes, but some programs depend on Page file and you can't disable it. VDJ is working good without Page file.
geposted Thu 22 May 08 @ 10:05 am
i read Sky's link .....apparently you should have at least a small page file on the C: , you can have page files on more than one drive , and it's better to page to a drive or partition w/ FAT32 .....
geposted Thu 22 May 08 @ 12:15 pm
