1- I have VDJ and I want to buy a dj control, i been doing some little partys, but now they want me to go play in a wedding and I need a control just to make it easier..
which one do you guys recomend me?
2- where can i find a usb with 2 audio outputs?
so i can split the main audio and the headphones audio.
geposted Fri 23 May 08 @ 2:09 pm
Hi
If you bought VDJ, please enter your serial here to get all the updates:
http://www.virtualdj.com/fusers/modifuser.html
1. Depends what you need, you have various options and some of them you can see here:
http://www.virtualdj.com/products/hardware.html
2. You can take some controller with built in sound card like Hercules DJ Console MK2 or RMX. It has all you need.
Other cards recommended are (from lowest price to highest):
Sound Blaster Live 5.1 USB
Numark DJ/iO
Maya 44
ESI U46DJ
Numark Virtual Vinyl
Hope this helps.
Numark DJ/iO
Maya 44
ESI U46DJ
Hope this helps.
geposted Fri 23 May 08 @ 2:36 pm
how bout if my laptop has 3 audio outputs already do i still have to buy that sound card?
geposted Fri 23 May 08 @ 2:48 pm
No, you can use internal sound card if you have 5.1 channels built in. Internal sound card these days have performance like Sound Blaster Live, if not even better ;)
Make sure you test before you go live. And make sure that your demo does not expire ;)
geposted Fri 23 May 08 @ 3:19 pm
