Hello Everyone,
Are there keyboard shortcuts for the VDJ parameter knobs for the effects?
Thanks in advance.
FLEX
Thanks in advance.
FLEX
geposted Fri 23 May 08 @ 9:05 pm
I think not as those knobs require analog faders like on controllers, you can't have that on the Keyboard. You can make shortcut in Config>Keyboard Shortcuts.
geposted Sat 24 May 08 @ 9:32 am
Indeed there are.
For sliders you can assign relative +/- values, to use it the same way as a pitch fader,
or use absolute to put the knob to a certain position. If you have a midi controller with
faders you can assign those easily in midi configuration.
geposted Sun 25 May 08 @ 9:05 am
I just experimented with the 1st slider with shortcuts +/-.
Thank you.
geposted Sun 25 May 08 @ 9:25 am
