hey guys,
sorry for bad english:
running vv 5.07 on a regular windows mashine and on a boot camp partition of a mac book - both xp sp2 - akk music and videos on an external harddrive (have two both working fine)
ok my problem is that if I start the program with running turntables both decks are spinning cool - if I wonna config the time code signal one deck all of a sudden starts spinning at ultra high speed a an error message pops up - no signal bla bla bla.
If I shut down the program and unplug/replug the sound card it will finally work.
But after a few hours suddenly a new songs just loaded in a deck will only load for a few seconds (in both waveform windows...you know what I mean) - if I load another songs that will sometimes works sometimes not - after I while I am not able to work because no song will get loaded anymore.
I have to shut down the software - restart and everything will work again for a few hours........
I am lost - how should I go and and work two nights with this software?
geposted Sat 24 May 08 @ 11:07 am
How does your time code signal look could you post a screen shot?
What is your system specification?
Are this fixed bitrate files or Variable?
geposted Sat 24 May 08 @ 5:39 pm
