when i try to load up videos i get "error in video card" message. got a gig in a couple of hours what should i do?
geposted Sat 24 May 08 @ 12:23 pm
Hi , do you have msn or ichat i can help you with this , if so pm me.
Make sure you have got your external display enabled before enabling the video.
geposted Sat 24 May 08 @ 3:01 pm
I enabled the external display and that solved the problem thank you. Which video transitions & effects are compatible and where do i get them?
geposted Sun 25 May 08 @ 4:14 pm
https://virtualdj.com/addons/videoeffects.html
Transitions which are shown as mac compatible. , are available.
Full FX on their way.
geposted Mon 26 May 08 @ 11:50 am
I am having a hard time showing a video effect when playing an audio only file. I downloaded video effects from the Virtual DJ site but am having problems getting them into the software. I keep getting an error message. Would appreciate any help. Thanks in advance.
geposted Wed 09 Jul 08 @ 4:17 am
