well basically i been useing Virtual dj for about 4 months now and i was just so used to it
last week i bought my first "very basic" setup the cdm3600 package
--->http://www.whybuynew.co.uk/images/uploaded/gemcdm3600.jpg
Ok Hers My question Would there Be ANY way at all that i can somehow use Virtual Dj With The cdm3600
for example like i drag a song from virtual dj onto the vdj players and control everything through my cdm3600 ?
is there anyway to use the two togheter? if so how do i do it? <3
thanks alot for your help guys
geposted Sun 25 May 08 @ 3:13 pm
Well first off support Atomix by buying VDJ and registering your login here at virtualdj.com.
Then buy a sound card for your computer. Set it up as you would with turntables. Download and burn discs with the time code and insert them into the players. You will be able to set a cue point and start the song that way. You may even be able to scratch. I don't know anything about the system you purchased.
geposted Sun 25 May 08 @ 4:50 pm
Please fill in some informations about your setup.
Which Hardware (Notebook, PC, MHz, XP/Vista, ...)
Which version of VDJ. (Home, Pro, 5.0x, 4.x, ...)
You will get yout support, but first register your software in your profile:
http://www.virtualdj.com/fusers/modifuser.html
Greets, Heiko
Greets, Heiko
geposted Mon 26 May 08 @ 5:43 am
