I've done a forum search but can't seem to find the answer. I want to use 12 pads on my padkontrol to activate the 12 pads in clipbank & the bottom four pads for other plugins like slideshow, camera, etc.. Does anyone know how to do this? I go to config. > remote control > midi > config> video > video_select_fx_multi, and I enter 0 but the pop up list doesn't appear. I know I can just enter the name of the plugin in the value box, but I still need to know how to a: assign the 12 clipbanks individualy and b: how to make the plugin not only switch to said plugin but to activate plugin at the same time;^]
Sorry for double posting, but nobody seems to ever offer me any help except in this forum;^]
geposted Mon 26 May 08 @ 5:18 pm
Jeeez, am I really that bad that I don't even deserve a response anymore? I certainly haven't done anything wrong, All I want to do is map the clipbank to my padkontrol.
geposted Tue 27 May 08 @ 5:06 am
tim you ain't bad, maybe no one may have any experience of this pad to pass onto you or they may be on holidays or have work commitments at the present time...
geposted Tue 27 May 08 @ 6:06 am
Thanks Tayla, it's just frustrating 'cause I've been trying to get an answer since friday (http://www.virtualdj.com/forums/90473/Hardware_Technical_Support/Controling_Clipbank___Other_Video_Plugins_.html)
Shouldn't the general midi config. method be universal to midi controlers? btw, in case anybody doesn't know what the padkontrol is it's the bottom controler in this pic;^]
geposted Tue 27 May 08 @ 6:13 am
Sorry Timmy, I would help but I don't use Clipbank yet ;)
geposted Tue 27 May 08 @ 7:59 am
Question for you Timmy, Can the Clipbank be controlled by a midi device, is it possible in the first place?
Maybe yes, maybe No. Sorry I couldn't help you mate on this one.
geposted Tue 27 May 08 @ 9:48 am
Thanks for your responses Jimmy & Alf. I've got my first pad already configured to switch to clipbank from other plugins, but I still have to use another button to activate/ deactivate the plugin & still have to use the mouse to switch from clipbank 1 to clipbank 2 & so on. If assigning clipbanks individualy isn't possible then I think the teamers should make it possible in a future release, the clipbanks are setup on the screen like an MPC & it would be very useful to use such a controler for the individual clipbanks;^]
geposted Tue 27 May 08 @ 12:12 pm
Ok, figured out how to activate/ deactivate using the same button (just have to map the button twice), now just need to figure out assigning each clipbank individualy;^]
geposted Tue 27 May 08 @ 12:27 pm
Try video_fx_button (Value is the clip number - 1, e..g: 0 = Clip 1, 1 = Clip 2, etc.)
geposted Tue 27 May 08 @ 12:45 pm
The man of the moment is on the case too, Timmy. You might get somewhere now mate ;)
If you do manage to do this , it would make a good plugin for the software.
geposted Tue 27 May 08 @ 12:50 pm
Ok, that works with one exception, I have to enter 0 for clipbank 1, 1 for clipbank 2 and so on. So if I map each button three times it does EXACTLY what I want it to do. Thank you so much, I knew there had to be a way!!;^]
geposted Tue 27 May 08 @ 12:57 pm
Absolutly, this is fantastic!! Except now I might be up all night playing around with it..lol;^]
geposted Tue 27 May 08 @ 12:59 pm
glad to see you got it sorted...
geposted Tue 27 May 08 @ 1:17 pm
Thanks Tayla, will be hitting up your collection very soon..lol;^]
geposted Tue 27 May 08 @ 1:56 pm
your more than welcome as usual, pole dancers are still popular hehe don't know why... think i need to do a bit of updating to that section in the near future though... lol
geposted Tue 27 May 08 @ 2:01 pm
haha, pole dancers would kick much arse, I have to drive over 100 miles to see one of those..lol;^]
geposted Tue 27 May 08 @ 3:36 pm
they are animated but jimmy likes them, lol, so does.... now that would be telling, hehe
geposted Tue 27 May 08 @ 3:39 pm
lol.. well that's about the best we're allowed here in the bible belt, my state (VA) doesn't take kindly to pole dancers..lol;^]
geposted Tue 27 May 08 @ 3:44 pm
Mmmmmmmmmmmmmmm, I like Pole Dancers.............even if they are animated. I fancy Jessica Rabit....
anyway I want go into that, is that wrong?
geposted Tue 27 May 08 @ 5:12 pm
jimmy don't even think about it, she's a right slapper, cost me a fortune to keep those stories out the press...
geposted Tue 27 May 08 @ 6:21 pm
