Hi folks,
Can you search files by BPM in VDJ 5.07?
I see that if you click the circle to the right of the search box you can specify BPM but when I type in 152.00 for example it doesnt search for all tracks with 152.00bpm ?? Am I doing something incorrect?
Thanks,
Thanks,
geposted Wed 28 May 08 @ 8:40 am
You are supposed to typ it in as a range. For example if you want tracks with 152 bpm, u could type in the search box "151-153" and it will retrieve you songs with bpms in that range
geposted Wed 28 May 08 @ 8:54 am
Yep got it, THANKS! :)
geposted Wed 28 May 08 @ 8:57 am
