Last night i found out that setting the color quality to 16 bits in the monitor settings makes Vdj a lot, lot faster....
i have a pentium IV 1.7
256 ram
40 gigs
nvidia video card
sound blaster 128 & Onboard soundcard
try it and tell me your results
256 ram
40 gigs
nvidia video card
geposted Sun 02 Jan 05 @ 5:00 pm
Upgrade your memory and you will see better results! Buy the program and you will open up a whole new world of wonders where you will be amazed at what you can do next!
geposted Sun 02 Jan 05 @ 6:19 pm
Ohh, I gotta try that. If that is the case, then a simple skin will improve the performance?
geposted Sun 02 Jan 05 @ 6:34 pm
Not actually, any skin would work with that......
geposted Sun 02 Jan 05 @ 7:36 pm
Lower resolution may have free'd memory for you, especially if your machine uses shared memory (which means video memory comes from the main memory pool).
As Vantinedj suggests.... get more RAM ! 512Mb is minimum recommended.
geposted Sun 02 Jan 05 @ 11:15 pm
