I just got my 2nd mac and on the new Mac Book (I have a pro and they both do the same thing), when in automix mode: It only plays off one player and cuts into the middle of the song when it mixes??
Is there a solution for this??
Help please!!
Help please!!
geposted Sat 07 Jun 08 @ 7:54 pm
What is ur setting in automix?
geposted Sun 08 Jun 08 @ 4:41 am
Cross length doesnt save when trying to change it.
geposted Fri 13 Jun 08 @ 9:20 pm
This issue will be solved in 5.1
geposted Sat 14 Jun 08 @ 4:38 pm
click on the "+" in the playlist..then choose your automix type ( don't use smart) and make sure the automix length is set to what you want it. It's not the crossfade that's the problem. As far as it using only one player, it's that way by design...i don't like it either.
geposted Sun 22 Jun 08 @ 12:15 am
