I have:
CDJ200
Numark DXM mixer
Fast Track Pro for audio
and a dell laptop
I've searched the forums for hours to resolve this issue. Nothing seems to be working. I burned the TC CD and found another thread to remove -14db. Tried that no go. All I hear is a loud white noise. VDJ doesnt detect the timecode at all. let me know what information you need to help me out with this.
thanks
CDJ200
Numark DXM mixer
and a dell laptop
thanks
geposted Sun 08 Jun 08 @ 10:28 am
I hope you are using this with 1 timecode CD player and not trying to use 2.
The FTP only has 1 Stereo INPUT option using Inputs 1 & 2.
As to the noise, it is because you need to MUTE the Input Monitor features within the FTP's control panel.
If you are montioring the input with any sound card, you will not get 100% signal and you will here the Timecode signal in your outputs.
If you have the GAIN on the soundcard's INPUT to high you will not get timecode control quality you are expecting. Start with the gain at or under 50% level.
geposted Sun 08 Jun 08 @ 10:40 am
