Forum: Old versions
Topic: VDJ - Stuttering on 1 when loading 2nd song
Using VDJ 5.0.7
Operating System XP Home SP2
P4 3.0 GHz
1 GB RAM
I sometimes (not always) get a stuttering on the current playing song while loading a song on the other deck.
I'm guessing that the right settings in the "Performances" tab would take care of that? Any suggestions for all those settings?
(As I write this, I'm also thinking it could be the WAV files vs. the MP3 files - Maybe VDJ doesn't handle the larger file as well?)
geposted Tue 10 Jun 08 @ 5:00 pm
Is your music on external drives? If it is, how do you have them hooked up? USB, Firewire, eSata?
All my music is on internal drives.
Just a suggestion...I would up your ram to 2 gb. 3 if you can afford it. Its possible that your computer is having to go to the hard drive instead of the ram to get information. This would cause bottle necks in information. What kind of video card do you have? Are you using vinyl or cds? Also when you load a song is your proccessor maxing out?
