Forum: Old versions
Topic: loop
And please, give me an step by step: I want to select a part of a song and repeat it endlessly. I didn't find it easy on the DJ Console. Set up a couple of cue points, but then how I tell the machine to repeat from cue point 1 to cue point 2 endlessly?
Thanks again.
geposted Tue 04 Jan 05 @ 8:06 am
I don't know the console but:
-> Click on the loop buttons on the skin (1/2, 1, 2, 4), try what you want. It corresponds at the number of beats you want in your loop.
-> You can adjust with the rotative buttons on the skins or with shortcuts.
-> Make sure your CBG are under the beats and your BPM well assigned in order to have good loops.
some skins allow you to set IN and OUT point of a loop.... manually
