Forum: Old versions
Topic: No ASIO Card In MAC??? Please Help
4-jrodPRO InfinityMember since 2007
Ok...First here is my set up:
Mac OS X V. 10.5.2
Sound Card: M-Audio Fast Track USB
Total Control
1) If I Config the following I get no sound
Input: None
Output: Headphone
Sound Card: 4-out card
Driver: M-Audio
Channel: Master: right/Heaphone Left
2) If I Config the following: I get no sound on my heaphones...And if I do, my heaphone volume works as my master volume and needless to say my "master volume" also works accordingly.
Input: None
Output: Headphone
Sound Card: Mono Seperated
Driver: M-Audio
I have a PC as well and I use the same set up w/o any problems...Though, my "conf" gives me a lot more options than my MAC....Any suggestions will be greatly appreciated,
Thanks
Jrod
geposted Fri 13 Jun 08 @ 9:18 am
spinnaJPRO InfinityMember since 2004
Hi there, for ur info mac did not use asio, it use core audio.
Have u create it as the aggregate devices? Are u using external mixer?
Regards.
geposted Fri 13 Jun 08 @ 3:54 pm
No, I am not using an external mixer...I am just using a Numark "Total Control" MIDi....What do you mean by creating an aggregate device??
Thanks
geposted Sun 15 Jun 08 @ 12:28 am
DJ CyderPRO InfinityModeratorMember since 2003
geposted Sun 15 Jun 08 @ 1:22 am
Yes pls look at the link given by Dj Cyder. U need to create it in order to use ur soundcard.
Regards.
geposted Sun 15 Jun 08 @ 4:16 pm
Hello, I use Denon HC4500.
What can I do? The same?
Yes.
geposted Sun 15 Jun 08 @ 4:21 pm
Thanks guys...I got it working!!!
Really appreciate it,
Jrod
geposted Mon 16 Jun 08 @ 11:15 pm
Glad u sort it...njoy;)
geposted Mon 16 Jun 08 @ 11:18 pm
Hey fellas, I'm plannin on buying u46mk2 for my mac. Just to clarify (because i'm still learning about mac) I have to do this for any soundcard that goes into mac right?
geposted Mon 23 Jun 08 @ 12:14 pm
Yes, except some card such as the numark box n the herc mk2 etc.
geposted Mon 23 Jun 08 @ 1:39 pm
Hey guys, I have a Numark Mixdeck and the MIDI controller in the middle will not work no matter what inputs/outputs I use. Any ideas?
geposted Mon 27 Dec 10 @ 2:53 pm
migue30Home userMember since 2011
hi all
i have a friend who has a macbook pro and he wants to install
the asio card for use with virtual dj and makes running
can some one of you tell me how he can do it please?
thanks
geposted Sat 17 May 14 @ 6:12 pm
Mac's don't use ASIO; that is a technology for Windows PC's.
Please start your own thread with specific details.
geposted Sat 17 May 14 @ 6:48 pm
